2nd Gen Non-Engine/Transmission Front Brake lines on 2500 1995
2nd Gen Non-Engine/Transmission weight of the bed
Engine/Transmission (1998.5 - 2002) transmission from a V10
I just completed installing the one ton Chevy rear drum cylinders,new hubs and new shoes. All NAPA stuff.
I sprayed the connections with PB Blaster a couple times the week before I started the work so taking the fittings apart was not to bad.
Glad is did that so now i worry about the front rubber lines.
I plan on applying the PB Blaster to the front connections like i did the rear.
Is there anything special aboput the front?
Do I jusr replace and blead like the rear?
RMcKinney 1995 2500 Stock 2745686 miles and still funning fine.
No different bleeding procedure, start at the furthest point away from the master cylinder and work your way up. Might want to take a good look at the jumper line that goes underneath to the passenger side front, mine was questionable when I replaced my hoses so I went ahead and made a new line.
Looking at your sig, is that right? 2,745,686 miles? Please tell me more!
To many places
274,568.
Sorry to mislead you.
