Dude! I so cannot believe your timing on this topic!
I had my truck in to the Dealer to fix my fuel sending unit because the gauge reads full all the time. I also asked them to look into the braking problem I am having in 4wd. The end result is that the front pads need to be replaced
. I only have 30kmi on the truck and I have an e-brake. Is this normal? I am guessing that it is by what some people have been posting.
What would be a good replacement pad? I have heard the Autozone HD pads are good. But there are no Autozone's here. Is there a premium pad from NAPA that would be just as good? Any help would be appreciated. Thanks.
*Update-I forgot that there was
this thread when I was writing this post. I've found the NAPA premium pads for $52. 95 a set. NAPA part# AE7339M. Sorry 'bout that. *
BTW, the fuel gauge problem is supposedly the fuel pump module. I thought it was the fuel sending unit in the tank. Are they one in the same? Or is the module what the sending unit sends it's signal to before it is processed by the PCM?
'99 2500 ISB QC SLT (No Leather!), 4x4, 5sp w/McLeod, 4:10, BD-II, PE, PE-EZ, 4"exh. , Pac-Brake, A-Pillar gauge pod w/boost and pyro, Line-X, V-1, lights, siren, lic. plt. frame says "
Diesel Fumes Make Me Horny!", and much more goofy stuff.
[This message has been edited by Amianthus (edited 01-05-2001). ]
