2nd Gen Non-Engine/Transmission Front brake pads which dealership is right?
2nd Gen Non-Engine/Transmission brake switch adjustment
Engine/Transmission (1998.5 - 2002) HX40w ???
After reading several old posts on brake pads, the concenus seems to be go with OEM or upgrade to so specialized aftermarket set-ups.
I decided to go with OEM this go around. I called one dealership, gave them the last 9 digits of the VIN number and the guy said they don't have them, but they can get them for $80. I called one closer to work and gave him the last 8 digits of the VIN and he said he had them in stock for $56.
Who has the right story?
- Dave
Don't know but make sure they are the same part number, If you post the part number somebody else who got dealer pads might be able to help out
Check your Geno's catalog pg 62 OEM 54. 00 Hawk Hi Performance 73. 00. Don't forget to change the brake fluid. Plus shipping.
I'd guess that the lower price might be an aftermarket pad... . Think about this... They have to use OE parts on warranty and customer pay work in the shop... . but I'd be they would use a less expensive aftermarket pad on cars for the used car lot and for some over the counter sales where they have to compete with others... .
I use a high quality Performance Friction product... . We like them because of the higher coefficient of friction and the better resistance to heat fade... we usually get very good mileage on our trucks but also pull heavy loads... . We don't use special rotors, nor do we turn the rotors unless we need to...
But we always flush the system and only compress the piston after the bleeder is open... .
Dodge sells a "value line" replacement disc brake pad for $59. 95 front or back. I'm not sure this is exactly the same as the factory supplied part.
To consider what jelag noted, I have seen invoices come out of the dealer with that little telltale "*" next to a part. . footnote says something to the effect of "a high quality aftermarket part was installed in your vehicle... " so dealers do use aftermarket parts and do offer them if asked. This might not apply to all dealers.
What ever happened to Sam Peterson? He was a serious brake guru here awhile back, and I remember he always recommended the Performance Friction pads and shoes.
Mike
I
I use Performance Friction on all my vehicles where there is a part number. I discovered them sort of by accident. My brother used to race in SCCA. He found that the $40 performance friction pads lasted through one race and actually worked better than the $200 pads (which also lasted through one race).
In installed Performance Friction pads on my truck after I smoked the OEM pads pulling a trailer down the grade from the Mogollon Rim into Camp Verde. They've been great and are not hard on the rotors.
