Front Brkae Pads
EZ upgrade ?
bulldog............any.good?
Getting ready to do front breaks. Should I get the pads from Dodge? I don't want to change the breaking ability of the truck by putting un-proven pads on. Does anyone have suggestions as to what pad might be best?
Thanks
Troy
2001, 2500 Black 4x4, Bank Power Pack w/DD1's, DTT T/Q and VB, K&N. Max Boost about 38lbs Pulling a 9000 Weekend Warrior full of dirt toys for the whole family.
1974 Powerwagon, fuel injected 360, custom suspension for that killer off-road ride... . :)
Troy,
Go with the Carbo-Mets,Sam sells them and they are GREAT. Good stopping power with no noise. Thanks Sam
Rich
I've been wanting to try the pads advertized in J C Whitney. Great claims to fame. What I DO WANT is a pad that is at least as soft as the OE pad. I'm not interested in longer life at the expense of rotor longevity.
99' Quad 4x4 A/T LB 3. 54 45K Miles.
26' Terry w/slide (7500GVWR)
"KISS your truck and it will be forever faithful"
What is SAM's. I live in Southern California. Why are the stock pads so bad? They have worked great for allmost 30,000 miles.
Troy
I've got 40,000 plus miles on mine, and when we rotated tires a month ago, they were fine. How many miles do you expect to get out of a set of pads? If I get 50 or 60,000 out of Dodge pads, how many might I get out of "good" pads?
Ray
01 QC LWB 5 spd, trailer tow pkg, camper pkg
VA, PS boost module and elbow, PS heater saver
Rotated tires last week and checked brakes. 40% wear on front and 30% on rear shoes. Just turned 30k miles. BFG A/T 35% wear in 20k mi, 15k mi towing, did not tow the first 10k mi.
2K, 2500, Quad, SB, 4x4, 3:54LSD, A/T w/ DTT VB, TC, TC SAVER and AUX COOLER , REESE 15k 5th slider, EASLEY BULL BAR, MAAP NERFS, BFG-TA's, 9000's,TORQUS MAXIMUS 505 lbft ECM, stealth DD2's, Bully Dog Boost & elbow, ISSPRO pyro, boost & transmission, Turbo Lifesaver, JARDINE 4", PAC BRAKE, MAG HYTECH TP& DC, AFE filter, GEAR VENDORS OD, TAYLOR WING onboard.
MxM's on order
pullees:
#1 y2k ARTIC FOX 5th
#2 22' car hauler w/ 76 Pinto 392cid or 68 Cyclone GT Cobra Jet FB
NRA-LIFE, VFW-LIFE, SoCSA-LIFE, SASS
Guys--Everyones driving habits are a little different. Some get good mileage and braking on the dealer pads and some hate them. What I have experienced is that carbo met pads do a better job than the origionals in that they usually don't wear the rotor face due to the carbon lubricity of the pad. They last longer with no noise and I think that you will find quite a price difference & better brake ability is also noticible. ---Sam
Where can I get the CARBOMET pads. I am ready to do my breakes.
Troy
One thing I do NOT like about dealer pads is the excessive brake dust. Granted, I have an automatic transmission - but I'm generally very light on the brakes, and do very little towing. My wheels are completely brown from brake dust in just 1500-2000 miles.
Do these aftermarket pads have comparable, or less amounts of brake dust?
Greg
I just installed some Titanium pads on the front. They stop alot better than the oe pads. The oe pads would have lasted another 10K but as I had just hit 100K on the truck I desided it was time to replace them.
EAT'M UP
97 2500 Club 4X4 3. 54, Forrest Green/Driftwood, LSD 5 speed, & Psychotty Air System, TST #11, 370 HP injectors, timing at 16 deg. , 16CM2 housing, AFC spring kit, TST EGT gauge & 0-60 boost gauge in A Pillar, Cat-be-gone, 4" Dynomax Bullet muffler, Crome 4" turn down, 2 Electric Fans, One inside/ One out front, AmsOil Through out, Geno's trans filter kit, AmsOil Bypass system, Lund Winter front, Leer Cab Level Shell Driftwood , 255/85R16, South Bend's Hypo Clutch*NRA/USPSA member and proud of it*
I think I'll just remove the 'Titanium' faces off my golf clubs and use them for my front brake pads, and save some money, since I can't seem to get below '100' on any stinking golf course with these over-rated clubs! #ad
Y2K Awesome Black LB 3500 QC SLT, 24Valve ETC ISB, 4x4, 4:10 LSD, DTT Custom prepared Auto transmission VB, Power Edge 'EZ', DD2's, K&N, Polished Stull Billet Grill/Fog inserts, Chrome Smitty-Built Step Rails, Mopar Chrome-Tipped Mud Flaps, A-Pillar mounted West-Tach Turbo/Pyro/Trans Temp gauges, Rancho 9000's, Diamond Plated Tool Box, + a bunch of other stuff. Fact:The First Fords' had 'DODGE' Engines! The new PSD's need them!
Hey I would like to see 100. That sure beats 112. I used to play with a guy that bought a new set of clubs every time he had a bad day. He just didn't know about operator error.
