2nd Gen Non-Engine/Transmission front bumper droop
C
2nd Gen Non-Engine/Transmission Leveling Kit and 35's
2nd Gen Non-Engine/Transmission 1996 radio/cd player
Sorry, if this has been posted before... I did try a search... the front bumper on my truck has the droop going on... . I see no adjustments anywhere... I backed off the side support bracket bolts, but that didn't get it... any ideas on how to tilt this back up so it's tight against my fender ?
Thanks
believe there is 6 or 8 bolts. The brackets that connect bumper right to the frame then there is a two more support brackets that 45 off the frame loosen all of them and it should lift up
Loosen all the bolts in the supports, use a jack to raise the bumper to the level you like, and then tighten the bolts. I had to lower the bumper to install new Sport Lights a while back, and that worked for me...
Thanks guys... . I tried those brackets once before. . jack and all... . I'll give it another shot and see if that'll work...
Thanks again
C
Raise the hood. Loosen the bracket bolts. Grab the top front of the bumper and pull forward. It will swing up. Have someone tighten everything. Ive done mine twice. Cant keep the bolts tight enough I guess. Lousey design. Good luck. Moe
Not only a lousy design but if they would have used fine thread bolts and nuts it probably wouldn't have come loose . . . #@$%!
