Front Bumper Not Straight?
Bacteria/algae in diesel fuel
HX35 or HY35 on 2001.5
Yesterday i noticed the front bumper was hanging down about 3\4 to 1 inch lower on one side. I went and lifted. wiggled it up and down. Does not appear loose. Any body else having- Front Bumper Drop?
I hit a deer with mine last year and had to have the front bumper replaced. The service manager at the Dodge dealer was not satisfied with the way it hung after it was replaced and sent it out to a body shop to get it right. From what he said the things are kind of tough to get right, but it certainly can be done.
Joe George
Eureka, CA
'95 2500 CC auto 4X4,3. 54,Combo EGT/boost guage,custom switch panel,PacBrake,TST #5,BD valve body,Automatic motorhome steps on both sides,Foldacover hard bed cover,Cummins chrome kit,Black steel grill guard,Front hitch receiver
Thanks Mark for the imfo. I haven,had time to look at,but its nice know it is a easy fix. My folks live in Fremont and I graduated from Fremont High many years ago. Two sisters live in Omaha. Small world
99-24V-2500-Laramie-SLT-A/T-LSD-355
All Options except cab lights and carpet-Rino- Prime-Loc-Alcoa wheels-Lund cold front-Factory Tows-DSG Electronic Fast Idle-Mag-Hytec transmission Pan+Rear Diff. Cover -Tekonsha Voyager- VA CPC -Rancho 9000-5000 steering stabalizer - BD exhaust brake - Auto-loc - Astroflex autostart -Bill K. T/C and V/B in tranmission -Prime-Loc removed and hanging in garage-Alaska
seems they all do it. Dunno why but simple fix indeed.
Y2K+1 3500 4X4 Quad Cab Powerpacked , Jakit's Front End Leveling Kit with 255/85R16 BFG M/T's Custom Rhino (as seen on website under tool man's truck feature) http://www.rhinoliningsnlc.com DeeZee Goodies, arb air systems 150 psi comp and air storage.
Keeping the rubber side down 'n' shiny side up Will Bring a smile at the end of each day (hopefully)
:D
They're pretty easy to adjust; loosen up the brackets where they attach to the frame (fornt of each frame rail) and line it up. Easier with two people -- one person to hold it in place when you're tightening it down. Note there are also brackets on the outside corners you may need to loosen and adjust. Takes an 18mm socket.
I have to do this every time I take the plow frame on or off; I measure down from the bottom of the corner lights to get it equal on each side then have one of my boys hold it in place while I tighten the bolts.
Big MAK
98. 5 ISB 5spd 4x4 Quad Cab 3500, 275s and Original PowerMax
A "WARRANTY FREE" ZONE
https://www.turbodieseltrucks.com
My front bumper came crooked from the factory. you can put your thumb between the blinker and bumper on one side and can't get your pinky between the same on the other #ad
. but it is easy to adjust. my last truck had a crooked bumper when I got it. Just something else to deal with.
2001. 5 2500 4X4, QC, Auto, 3. 54 LSD, SLT, SWB, Trailer, Camper & Snow plow Packages, White, 35k# Cody Hitch, 20' Gooseneck Lowboy flat-bed Trailer.
Mine was great until I installed the OEM fog lights. I messed with it a few times and finally gave up.
Things have a way of working out... .
My new tenant backed into the bumper and really messed up the alignment... #ad
But her 'Tracker' made out far worse than a simple bumper alignment.....
Mine did the same thing,took to dealer they loosened 6 bumper bolts and readjusted & good to go
2001. 5,2500,4X4,REG. CAB,ETH/DEE,PATRIOT BLUE/SILVER,RHINO LINER,AUTOMETER PYRO/BOOST
