GAmes
I have to change my seal because the old one leaks. I removed the front cover and installed a new seal. It was then that I discovered my crankshaft has a wear ring installed. (see pay it forward if you need the stock size) Michael, down at Hot Rod Diesel must have installed it when he installed the PDR cam, 207k ago. He might have told me, I don't remember.
How do I get the old one off and what is the best way to install the new wear ring? The mech at the Cummins shop says he heats the old one cherry red with a torch and pries it off with a pr of screwdrivers. I don't have an acetalene torch, and even if I did I don't think I want to mess with the temper of the crankshaft. I'm thinking Dremmell cutting wheel. That leaves me with installing the new one. The same mech said to install dry, no lubing of the shaft. Start it by tapping it with a 2X4 then use the old wear ring to drive it on since I don't have the special tool. If I cut the old one off I can't use it for the install and I'm not sure it would work anyway. If I put a bit of bearing grease on the shaft is there any chance it would spin? It seems to me that if the clearence is that loose then installing dry would take less force than installing bearing races into a hub. Any advice on R & R will be appreciated.
