jwilliams3 said:You dont need new gaskets. They are re-usable for years. Really good quality.
jwilliams3 said:Also on the front diff cover you dont have to remove it completely. I just unbolted it and let it drain then re-torqued the bolts and re-filled. As I remember I torqued the bolts to like 20ft lbs.
HLewallen said:I find it hard to believe you could snap the head off one of those bolts using the factory torque specification of 30 ft-lb. Are you guys going to 30? Are you at least using loctite? Mine came from the factory with red. Myself, I cleaned up the bolts and downgraded to blue. Factory torque specs.
HLewallen said:Ha - no, but they were a little tough coming out . . .
I realy need to get a bench grinder set up - I had to clean all my bolts with a little wire wheel using a power drill. Tedious, yet frustrating. That red stuff don't want to come off.
rbattelle said:I think that might have been red silicone sealant, not Loctite. Red Loctite can only be removed by heating (or by an extremely motivated person with a new 3/4" breaker bar)
Ryan
Turbo1Ton said:I always thought red was impact tool removal and green was the one you had to heat up.
Jeff
HLewallen said:Yep - that's them all right. Those are the best darn diff-cover gaskets I have ever used (they actually seem to work). I am used to older trucks and scraping silicone - was it just a fluke that they made these things servicable/reuseable?
