Hey all,
First I have a 1993 Dodge D-250 2WD, regular cab. I replaced my front pads with some aftermarket ones and I took off the front wheels to inspect everything (approx 3 weeks after install) anyways I noticed the outside of the rotor (the rotor facing you when you take the tire off) had no wear on the bottom 1/2". Meaning the pads are NOT touching the rotor 1/2" from the bottom. Does this make sence? The back of the rotor the whole pad touches the rotor. So I decided that I may have purchased the wrong pads so I ordred some pads from EGR part number 086 and there pads are the exact dimensions of the after market.
So is this normal to have 1/2" of unused rotor on the outisde on both tires and 100% rotor use on the inside.
Attached are some pics to make it easier to understand.
Any comments will be greatly appreicated.
Cheers
Cheers
