I was one of the 3rd gen truck owners that was SURE that my truck did NOT have the grease fitting not the front cardon joint. This was after THREE different dealership series managers told me my truck didn't have one (DESPITE having a sticker in the engine compartment that was telling me to grease the front card joint at every lube interval) and NOT being able to find it myself. (in hindsight LAME, but I did try to). The explanation/line I got from the different service managers was that at some point in time, Dodge went to a greaseless cardon joint and since my truck was a late model 2005 and since I hadn't actually found it myself I simply chose to believe them.
That is, UNTIL the day that I removed my front driveshaft while doing a major front end overhaul at around 90k miles.
You can perhaps imagine my surprise when after cleaning the cardon joint that I actually SAW the grease fitting that several dealer mechanics and managers had INSISTED was not there and that I had been unable to find myself. Since I was replacing the other drive shaft u joints anyway along with axle shaft joints,, I dissamlebd and inspected the cardon joint. I found it to be dry but NOT damaged. Since it appeared and felt undamaged I chose to disassemble it and thoroughly clean it then reassemble with plenty of good red grease in all of the right locations, That same cordon joint/frint drive shaft it has been in service since.
Of course, part of that front end overhaul included installing free spin hubs which keep the shaft from spinning while in 2wd, unlike the oem hub system, but I now grease the cardan joint at regular intervals and it has worked well since.
My point??
Depending on the use and condition of your front driveshaft, it might well be serviceable and you should probably inspect it closer and then decide what to do. If there is no excessive play or roughness or indications of heat discoloration to the bearing and spring, then you can safely decide to service rather then replace it. That said it does take a bit of elbow grease and a good helping hand to reassemble the double cordon as compared to a regular joint.
Just my LONG .02
