Bought a 2006 4x4 with 20,000 miles. Noted the instructions on greasing the front driveshaft fitting. Tried to grease it using a needle on my grease gun, only to have the grease push back where the needle plugs into the gun. Raised the driver side front wheel off the ground which changed the angle of the shaft. I was then able to pump grease thru the needle into the fitting. Should I be able to see any grease comming out of the u-joints or other parts of this fitting ? How do I determine when it is full and properly lubricated ?
Appreciate any input.
