Hey everybody, Happy 4th, I just took my truck in to check out wheel alignment as I got new tires and had some uneven wear on right side. they quoted me to change out upper and lower ball joints, right front U joint, front trac arm, rear sway arm links and tie rod to pitman rod. before they do the alignment. Supposed to be a real good alignment shop, but the quote for labor and all was around $2250. I'm not a mechanic but I looked up some of the parts-like Moog K7394 upper Ball joints and they were only $88. 00 versus their estimate of $200. 00 each. They were busy so might of messed up a little, but just wondering if this sounds reasonable for a 2002 with almost 300,000 miles? I did have the right U joint changed at 148,000 by schwab.
Any one have experience here??
Thanks.
Thanks.
