Re front suspension. A company called Gibbon Fiberglass Reproductions in Gibbon Nebraska (308-468-6178 from 1991 catalog) sells a number of kits to install the Cordoba parallel torsion bar kit into older Ford and Chevrolet pickups. They build the K member which installs on the original frame.
I bought one of the first ones they built and the design has changed since mine.
I bought a complete K member with the transmission mount/ torsion bar sockets and stripped everything off of it including the sockets which are welded into the new cross member. The donor was a '76 Cordoba (with rich Corinthian leather) with the 400 CID engine. In the case of the '53-'56 F100 style frame, the only cutting required was to inlet the frame approximately 3/4" to clear the steering box and two small cuts into the front crossmember where the core support bolts to clear the strutrod attachment points.
When I built the truck originally I cut the frame and grafted a '74 Ranchero clip in. It sat too low for my taste as it the center of the headlights were 22" off the street. Only then did I learn that state law requires 24" minimum **unless it came that way- another long story**
As I was driving to where I was working on the new frame, I was run off the road and ended up breaking the frame, bending the valance, bumper and both front fenders, 2 tires and wheels. Fortunantly I was able to keep from going into on coming traffic. I almost recovered it when I dropped back into the freeway and it spun. As I slid across loop 820 southbound, facing northbound I prepared for it to roll. Later, on inspection, there was road rash on the sidewalls to the inside of the lettering.
When I got it back in the driveway, it had 994. 2 miles since frame off total restoration.
The engine/transmission were already set so I just put it back in the same place on the new setup. I should have gone ahead and moved everything forward as the oil filter is tight on the steering box and I have never found a set of headers that would clear everything.
I am running a 302 slightly modified,
Tremec TKO 5 spd transmission, and 9"limited slip. Front tires are 215-70-15 rear 245-60-15 BF Goodrich T/A radials on Cragar SS wheels. I think I had the last guy put the alignment specs on the recipt. I will search for it. I can e-mail you pics of the truck and scans of Gibbons catalog. I am afraid if I post the truck on this sight, I might get tarred and feathered.
