Front end Bump Stops
what temp.is gauge reading?
The Common Rail ISB is in the road.
Went to grease the steering knuckle ball joints the other day, and looked at the upper control arm. I appears that there is a pad on the arm with holes for a bump stop. There is a corresponding bracket on the frame, also with a hole for a bump stop. Unfortunately, there is no bump stop installed. Is this Correct or did someone at the factory forget to install them.
01. 5 ETH/DEE QC, 2500 4X4, 3. 54 Everything but leather
