front end bushings
K&n or Paper.
Adjusted Pump - Wow!
Okay, I feel pretty low tech right now. I tried to do a search for the part numbers for replacement of the front end nylon bushings?? I plan to replace the steering shaft and at the same time I wanted to replace these bushings since the kit is inexpensive and easy to install. I know that Old School replied to a post with the part numbers and Boatpuller just finished a search on these, but my search for it failed.
In addition, any special way to search? I picked "any date" to pull the info from but never got much of a search result back. :confused:
Front end nylon bushings
Come on guys, gimmie a bone to chew on!!! Doesn't anyone remember that thread or can help me out.
Pleeeaaase!!!:(
OK!!
I'll try to find when I get home tonight. The new search engine doesn't seem to find things as well as the old. (IMO)
Did you try a search using Old School as well as one using bushings?
Ok, found the file in my computer (I saved them) but couldn't find them with a search. Shrimpy was the one that posted PN's for the 2 wheel drive and I have no idea if they are the same for a 4 wheel drive. The parts are Moog
upper control arm bushing - K7104
lower control arm bushing - K7192
Strut rod bushing kit - K7079
AGAIN, I'M NOT SURE IF THE 2 AND 4 WHEEL SETUPS ARE THE SAME AS FAR AS THE BUSHINGS GO.
I'll keep looking
Stan
19kgvw,
I've spent over an hour looking and searching -nothing else was found. Probably just not asking for the right thing. I tried!:(
Stan
King Pin bushing P.N.'s
The part #'s for the plastic king-pin bushing are:
p. n. 4384127- $10. 50 [need two]
p. n. 3894145- $1. 50 [ two gaskets]
Thank you Paccool and RDBuck!!!! I had a working emergency out of town and just got back. I didn't have any idea of what to replace or how to get there. Thanks for spending your time on that subject. I can now check with the dealer to look at the exploded view of front end components and compare between D and W series. All in the name of getting a tight front end!!!;)
If I can return the favor, I will. Rich
King Pin Bushings
19KGVW,
Check your TDR Issue 33, page 41, left column about the center of the page and TDR Issue 24, pages 66 & 67 gives details how to do the job.
Bill
