2nd Gen Non-Engine/Transmission front end clunk
2nd Gen Non-Engine/Transmission clunking front end
i have the new borgeson in... . didn't help the clunk.
i have the dss in... ... didn't help the clunk... .....
i have tightened the shock bolts. (rancho 9000's). no help.
new lindstad track bar... . no help... ... ... .
what could this be?
also, i feel it when i drop the pedal and when i let off of it quickly... ? as well as at slow speeds.....
thanks. scott.
Motor Mounts. I have the same problem. Ordered the parts but haven't gotten around to installing them yet. Probably do it next week. FYI dealer only parts. -Glen
Clunk!
Well
I too have a clunk or two.
Check the u-joints at the front hubs.
Then check the the rest of the u-joints.
after that check the rear end.
I have a nice,loud clunk coming from my rear end.
inspection has revealed worn spider gear thrust washers.
I'm sure it's from too many peg leg burnies.
any way I'm savin the bucks for a new rear end.
SFB
looks like i'll try the bearing preload tomorrow. i will also shoot some grease in the joint on the borgeson. i got one of those needle attachments for the grease gun today.
does anyone know where to get one of the spanner wrenches called out for in the bearing preload tsb? i tried napa, carquest, etc. in town. no luck... ...
Shendren try Harbor freight tools I bought a whole spanner wrench set for about $14 prison made of course, China. It worked great all I had to do is file the stubs down on the end of the spanner so they would fit into the holes on the nut.
