Took my truck into Dodge for aligment to correct pulling to the left. Needed track bar and driver side offset ball joints to correct "camber". I replaced the track bar with SS's bracket and a 3rd gen. trackbar. Dodge replaced the balljoints ( Wrong ones the first time so I took it back to be redone which they did after wrecking my hub and bearings - that cost!).
Still wanders to the left on a flatish road and to the right on a crowned road. Took it to an independent shop ( this time with my camper mounted) The camber readings left to right: . 32 , . 75
caster: 5. 76 , 6. 87
toe: +. 67 , - . 29
total ft toe: . 38
Spec sheet says the max caster is 3. 80
toe . 09
According to the post a few days ago on alignment the specs don't even seem close.
I'm wondering if the cab over camper weight could change the readings drastically . Dodge said they were right on. And said I'd just have to live with the wander????????
toe: +. 67 , - . 29
total ft toe: . 38
toe . 09
