I put the truck in the shop today to have the left front U-Joint replaced.
2004 Ram 3500, 4 X 4
The shop says they cannot get the hub off without heating the wheel bearing, which will ruin the temper of the bearing. So they want to replace the whell bearings for $300. 00 more.
1) Is there a trick to getting the hub off they may not know?
2) Has anyone else ever had this problem?
I understand that if they heat the bearing should b ereplaced, It just seems strange that they both won't come off.
Thank You in advance.
