Front end ticking.....?
Should I select the Pickup Box Delete option?
Rustproofing
Have an 05 610 4x4... about 25k on it, and theres an annoying ticking sound in the front end when making turns, sometimes when moving straight along. I havent taken it to the dealer yet about it, just too much of a hassle. I -think- it may be a u-joint, since theres no zerk on these things, I cant just grease it and see if it goes away. . Hopefully there isnt a problem with it. . cant afford for the truck to be down for any amount of time and wait for the dealer to putz around. .
any ideas?
thanks
-jerry
My '03 had a ticking noise in the front end, took it in last week, turns out it is the front axle U-joint on the drivers side, the parts came in and it is at the dealer right now being repaired. I only had 400 miles left on the bumper to bumper warrantee. I will let you know how it turns out, should be ready at 5 today.
Yep, I have the same thing. Mine is on the right front, so went to Napa and ordered it last week, should be in tomorrow. I just had the ball joint replaced with a greasable ball joint. When I get may tax return I'm going to go through the whole damn thing and replace what U joint's I haven't already replaced with greasable one's. What a joke the sealed one's are!!!!
yea thats what I think... its coming from both sides though... not good. I think I used 4WD mebe twice last winter. nothing since March though...
sigh. . guess a trip to the dealer is about all I can do... Anyone heard of the sealed u-joints failing? I got the 100k warranty on the truck for extra $$, so we`ll see how long they last. I just dont want them to fail 200mi from the shop... hmm
tnx
-j
All the u joints on these 3rd. gens are a problem. My thoughts on them is that there is very little or no grease in them from new. I had 2 rear drive shaft joints replaced on the $100. 00 deductible. I looked at the new ones as they were being installed and asked if they were going to put some grease in them. I was told "NO", this is how they are installed. They did not last neither. . When the axle joints went a month ago I got the Precision greasables and did the rear drive shaft at the same time. I am going to do the front driveshaft as soon as I get a chance. The factory ones are not good. My 94 had over 300,000km. before a drive shaft joint failed and close to 400,000km on the axle joints which were still okay. I actually prefer sealed joints but they need to be good quality and have some grease from the get go.
The 05 has the grease eye... on the front U joint. When you open the hood you see a sticker on the frount by the radiator... . requires a needle addapter for the grease gun.
Texbambam:
That joint is the 4wd shaft from the transfer case. I got the needle just havent figgered out where it goes heh
-j
Got the truck back this morning, everything seems good, they replaced the U joint, and checked the other side and the ball joints. They said everything was fine. They also said it would be covered by the 7/70 warrantee with a $100 deducable if they go in the future. While it was there they also did two recalls, one for an ECM connector and one for a trans cooling line. The door seals were wearing so they replaced those as well, the new ones are different, just like the ones on the '06s. All and all a good dealer trip.
