Its been a while since I posted this, so its time for an update.
I have replaced the entire front end. New ball joints, tie rod, tie rod ends, drag link, sway bar, sway bar bushings, sway bar end links, control arm bushings, new Kore suspension with steering stabilizer, new axle shafts and u-joints. Got it aligned to specs found on this site. Every bolt and nut is torqued to spec.
I find that I get a vibration around 55-65 MPH. Its a rapid "shimmy" that is felt through the floor boards, seats, as well as the steering wheel. It seems to be worse when turning. Its not there all of the time, but seems to come and go. Its there on both smooth and rough road. I am starting to think it is due to either the BFG's or my old $50 steel wheels. Tried rotating the tires, and it was still there, although it seemed to slightly change. Might have been my imagination... I have placed my hand on the transfer case shift knob and I don't seem to feel the vibration as bad as I do through the steering wheel. My steering box is shot and I have excessive steering play, and I am going to replace that soon, but I wouldn't think that is the problem. Any other ideas? Front drive shaft maybe? I am going to pull it off and then put new u-joints in the rear drive shaft and get it balanced this week before I spend a bunch on new wheels and tires. Its driving me nuts, and my girlfriend now wears a sports bra when she rides with me due to the bounce.
