I hate to post a "new topic" on something that may have been covered in previous months, but I wanted some specific advice on my situation.
First, my 99 QC 4X4 just turned over 162,000 miles and all I have changed is the fuel pump (at 130,000). That is, of course, other than oil, filters, tires, etc.
At this time, when I drive down the road at highway speeds (70 mph) the steering wheel moves WAY too much. I have heard and read of the "death wobble," but I don't think this is it. I can turn the wheel from 10 o'clock to 2 o'clock at 70 mph and the thing stays straight - well - with a steady right pull - I guess.
I have looked under the car (and had others do the same) when turning on the steering wheel. The best thing I can say is that the tracking bar (? terminology) and the bar off the pitman arm (tie rod end?), are moving up and down without turning the tires. There is quite a bit of play in the whole system Is this common? I can see how the truck would pass inspection if the tires were off the ground - no resistance. But if they were not.....
Either way, what do I need to change? The dealer had a tracking bar for $300, a tie rod end for $80 and the shock absorber for $113. I had planned on getting new shocks and tires (which are needed). Am I looking at the whole shooting match to correct the problem? Anyone have a similar situation? If so, is there somewhere else to get the parts a little... . um..... "less expensive?" I hate to be too cheap, the truck is paid for.
Any and all responses are greatly appreciated. Thank you.
