My buddy just bought a 98 12 valve that is leaking oil up front. It is a lot of oil (1 quart in 1000 miles) so I suspected KDP. I opened her up last night to find the KDP firmly in place and no sign of leakage anywhere I expected to find it. Front main looked good (replaced it for jollies because the cover was off) cover was tight, vac pump dry, injector pump dry, pan bolts tight..... What now? The best I can tell it's coming from behind the timing case on the drivers side, down low. Is this a common thing? I've never seen it before. I looked at a timing case from another 98 I had replaced and the gasket looks very narrow through there, could it have blown out? Thanks for the help.
-Scott
-Scott
