Front hub and spindle-Dana 60
Cotton Owens Enterprises Inc.
Speedi Sleeve for rear axle seals
Not sure if I'm using this forum correctly. Following parts are for 92, 4x4, 2500
Front spindle for Dana 60:
Drivetrain Warehouse-1-888-432-7656
Part # 3 D/S 700013 Spindle Kit... ... ... . $107. 95 (comes in Dana/Spicer box) Must have the Bill of Material #, 6 digit number stamped into your axel tube. My no. is 610357
Front hub for Dana 60: Dealer will not sell only the hub ,it comes with the rotor for about $360-400. The hub is a "dealer only" item according to Dana/Spicer. Budd,the original maker of the hub,is now owned by Bosch and they have no info. on the hub.
The hub can be bought for $200 from Ventures Truck Parts and Equipment, Ogden,Utah-1-800-464-1713. They have the hub made by the same company that makes gear for Warn. I have installed this hub, it is brand new and seems to be every bit as good as original. There was no part #.
For the Dana Hub you can also try Six States Driveshaft Co. - they now offer a new replacement hub that looks every bit as equal as the O. E. M. hub. According to them the internal spline hubs ( 1989 to 1993 Dodge and all GM 1977 to 1991 ) will interchange between each other -- so if you are in need try a GM hub also. Sorry , no parts #'s but I thought this info could help someone in need. Thomas
