Axle nut
The nut requires a 1 11/16" socket... 3/4" drive. Note: if you have the same experience as me, you will think the socket doesn't fit, but keep indexing the socket 1/8 turn and retrying. Wierd as hell, but my socket only fit on the axle nut when indexed to a certain position relative to the nut... I know, I know, not possible you say, but I had 3 other people independently try it and they all had the same experience. You will need the 3/4" drive because unless you have a really beefy air wrench you won't get it off that way. Mine took a 4' cheater bar and I had to stand on it and bounce up and down about 10 times.
A couple of hints: You can use a puller, but you will have about a 50% chance that you will pull the hubs apart. They are sealed units and most of the time you are not successful rebuilding them. New hubs are $360 ea. A much better way to remove the hubs is to loosen the 3 (could be 4... a while since I did it), 12pt, 9/16" bolts that hold the hub to the knuckle about 1/2" and pound them back into the knuckle with a brass or copper hammer. In doing so, you will push out the hub rather than pulling it out and taking a chance of pulling the hubs apart. Trust me, I have done it both ways and the latter is a much better way.
Good luck. PS the axle nut torque spec is 175 ftlbs and there is no backing off.
