So, I've got slop in my right front wheel bearing. Is it too much play if the rotor has worn through the splash shield on the inner side? It only has 1/8" up/down slop or so?
Ok, I guess it needs fixing. What is my best choice... ?
1) New bearings (&seals?) in existing hub? ... Have pressed in at machine shop.
2) New hub assembly with bearings? Best source $ ???
3) New 00 or 01 hub assemblies + rotors to make it easier to R&R rotors. Don't necessarily know if the newer ones with the rotor outboard will even work or not.
I replaced the right front rotor 50K ago and when I did it, the hub would not come off the knuckle. Ended up pulling the bearing apart with a LARGE puller. Got the new rotor on and pulled the bearing back together with the axle nut. Didn't know how long it might last. Guess it's not too bad with 50K miles after that.
What is the best way to get the hub inner race off of the knuckle. 3 yrs ago it would not budge and I expect the same this time.
Thanks
-Deon
Thanks
-Deon
