Details here: TDR Privileges
I need information on supplier for front hub disconnect. I want to use the 4lo to back up my fiver in some tight spots on pavement. As I recall, there is a member that either makes, seels or has plans for them.
Look up memeber BobV. He makes/sells a vacuum switch so you can use 2-lo. I really enjoyed it on my 99.
Other options available are a kit by BD or home made solution that uses a solenoid out of a Honda. You can find much information if you search for 2 low or 2-low
