2nd Gen Non-Engine/Transmission Front hub to steering knuckle bolts
Engine/Transmission (1994 - 1998) leaking delivery valve
I broke two of the hub to knuckle bolts while removing them for rotor replacement today. Called my local dealer and was told that they could not find a P/N for the bolts, just buy some off the shelf at the hardware store. Now I know that they are 14mm with the 12 point head, also graded as 10. 9 and just any bolt will not work safely. Does anyone know the Dodge P/N or another source?
try a different dealer ... . or call theese guys with the bolt specs and they will have it. They are right up the road from me and they specialize in ..... well EVERY nut and bolt known to the human race. OR try another dealer that may actually look up a fische :rolleyes:
Don't put in just any old screw that will fit. Make sure you use (at the very least) the same grade, i. e. 10. 9, cap screw.
