Have the 12v out of my 98 pulled and tabbed and changed front main seal. Although Cummins supposedly started using loctite on 98's checked the bolts and didn't find any loose. Installed wear sleeve and seal on cover. When dry fitting, whole opening looks to be cockeyed on crank. Checked the front cover for damage with straight edge and reinforced area in back is straight. Don't see any damage to cover. Is this supposed to be this way? Going to plan on using Thanks. Paul in Alaska
