I have had an oil leak from the left front of the motor for some time. This fall I checked and sure enough there was oil dripping from the vacuum pump. I got the repair kit from Cummins and did the repair. The next day I took the truck to town. I stopped the motor to run my errands and looked under the front of the truck and saw some black drips in the fresh snow. My first thought was another attempted repair gone wrong.
I don't consider myself a skilled mechanic. I like a challenge and after checking the threads on the repair I thought I can do this. When I got home after the truck dried off underneath I started the motor and checked my repair. Expecting to find oil dripping off the vacuum pump I found none. Whew! But what I did find causes me more concern. Oil appears to be leaking from where the gear case meets the block on the left side of the motor. It is hard to see in there.
My question, is my guess correct or what else would I check?
My apologies for the longer thread. Any advice would be appreciated.
Thank you
Stan
Thank you
Stan
