OK, I thought I'd post this as it's own thread instaed of tagging it onto some of the KDP and gear case discussions going on now.
I'm currently reassembling my truck after tearing it down to do the KDP prevention and finding a cracked Fuel Gear.
I got to the point of installing the front seal and wanted to pass along a tip. I would get a chainsaw file and bevel the seal lip in the front gear cover while it's off. It seems this lip is pinched at the outer nose of it making it a royal B__CH to get that seal started once the cover is on the truck. (you have to do it that way after centering the cover on the crank with the provided tool in the seal kit)
Just spending a few minutes beveling this lip in the seal bore will help a lot. sure wish I'd have thought of it BEFORE putting the cover on the truck.
When setting the seal, the bottom section will drive nicely as that part of the cover is really close to the gear case and is very firm. The top part of the seal is rather bouncy to drive in since the sheet metal timing cover is not really supported nearby.
Just a few tips I hope might help someone.
