Wouldn't you know it just when I thought I was done getting it ready for the Yellowstone expedition (leaving this Sat morning). I was giving the front end a few strokes
of grease that is and noticed the left side had OEM ball joints as I went accross noticed the right had new upper & lowers. The bottom zerk is fine as it drops straight down, the top one is at 90 degrees. Thats where the fun begins - I noticed the joint caps have little nics on them right in line with the %#$&!* zerk
Not a big deal in itself but, I think the axel seal is leaking slightly as the bottom of the housing is a bit moist.
At this late stage and since we're going on the trip Sat, I'm going to check the gear oil level and closely monitor the amount of moisture at every fill up. Then check the level again when we hit Colorado Springs before coming home. I think I should be OK? I don't plan on runnig in 4X at all.
Any one ever do a front axel seal? And, what do you all think about installing a plug in the bottom zerk then drill & tap one in the side instead?
