CAUTION!
The bearing preload on 94-99 Rams is created between the axle shaft shoulder and the axle shaft nut. Without pressure from the nut, the bearings will separate enough to move out of the center of the bearing races. If the truck is driven with the nut loose, the hub bearings will quickly fail, often within 25 miles.
I don't think that the hub and bearing assembly on 00-01 Rams is constructed differently.
Dave
