Front rotors- resurface method ?
Wire to rear diff?
IP questions
Two choices for resurfacing front rotors... .
1- remove from truck and turn on machine
2- leave on truck and have rotors turned on truck
Which will give the best end product? Least material removed?
Price is not an issue... only about 30$ different- opinions and personal experiences requested .....
I think leave on truck is probably a better deal as then they are true to the hub, if turned off the truck there is the possibility that they will not be perendicular to the axle shaft.
Caleb
On the truck is more accurate, it removes any possibility of lathe operator error in setting up the rotor true/square. The down side is that some on-car lathes don`t produce as nice a surface finish, but a well schooled tech can ensure a nice smooth job. All MHO of course
I had mine done on the truck and it took away the pulsating problem I was having. Had it done at Les Schwabs and cost about $60. I say do it on the truck.
The on the truck method is the best way. But finding a shop that has the adapters for our 8 lug setups is hard. Most shops just setup for cars.
Hey... Les Schawb in Bremerton has the adapters and capability... I think I'll stop by this week and quiz them on their knowledge- see what their answers are like. They want $ 79
hey, keep something in mind, if they were pulsating, then you might be better off with new rotors. my experience has been that when a rotor or drum has material taken off, it has less metal to disapate the heat, and in general will warp faster. just 2 cents worth.
ALso chekc your brackets to make sure the calipers are sliding on a smooth surface. Mine arent, and even with newly turned rotors, it made almost no difference. Been too busy (here) to take the wheels off and file them down.
DP
FYI... my son owns/runs an auto repair shop. He turns/trues EVERY rotor before it goes on the vehicle. New ones are not always good enough. NAPA, dealer, where ever they come from.
I've heard this before- it's good to always do a skim cut on new rotors ... ...
These rotors have approx 10K miles on them..... so I'm going to take a little thickness off but anticipate the cut to be minimal... hopefully. It's worth an effort. It's something that I'll have to monitor regarding before thickness and finished thickness.
