as some of you know when i did my kdp i installed a new front cover gasket & front seal(which is leaking)
now my teacher made me be sure that the inner lip of the seal was facing inwards, towards the engine.
also a small pick/screwdriver was used to push the lip in, ( probably damaging seal in process) what i see/read from my haynes repair manual is to just put lock-tite on outer ring of seal, and make sure no oil is on crankshaft snout, and to use the plastic seal installer/positioner (which we didn't).
should i just install the seal, like the manual says or purchase sleeve/kit?
sorry for my long windedness.
thanx again,
dt
thanx again,
dt
