How many bolts is there to check to see if there tight ? Im doing the KDP on a 94 engine and i can only see 3 and i got no way to get to the one behind the cam gear . Also the books says 18 foot pounds does any one have a conversion to inch pounds ? My 2 torqure wrenchs dont go down that low . but i do have a inch pound one as well .
Also what is the best way to install a speedi sleave on it as i nicked the crank serface getting the front seal out .
and what is the best and easiest way to get the front seal in as well as the rear seal ? last time i done a front one after the 3rd time messing a seal up i took the cover to a freinds and had it installed by him . as the driver is a joke
provided in the seal kit as s the KDP it moves then bends when you try tighting the bolt . all ideas and help is appreciated Thank You !!!!
