Front U-joint/constant velocity joint & warranty?
The last few days there has been a faint clicking noise, it sounds like it is coming from the transfer case shift lever. The noise is only heard when coasting either in gear or in neutral at any speed. When I shift into 4 wheel drive the noise is gone. Looking under the truck I noticed that there is about 1/16-1/8" play in the front drive shaft up by the transfer case at the U-joint (constant velocity joint). My first question, is this play normal? If not could this be the cause of the noise? And most important would this still be covered under warranty. The truck was delivered in October of 2002 and now has about 28,000 miles.
I thank all those who reply, Pete
