Front valance bolts
Should I remove my cat?
filter head fittings fit?
Does anybody know what size the bolts are that hold the front air dam on to the bumper? I received a new one last night from LMC and need to pick up some bolts.
Thanks,
Ben
6mm x 1. 00 pitch x 30mm long. they are a dogpoint style bolt . If they come off like mine, you'll be better off sawing off the air dam at each bolt point and then cutting off the bolts just above the clip as they rust into the clip and are very tough to hold while turning with a short 1/4" drive inside the bumper. Good luck.
