Well, looks like the left front wheel bearings are or nearly are toast. I was investigating a vibration, which turned out to be an exhaust leak (go figure
) , when I discovered that there was some play in the bearings. How much play?... ... ... when I had it jacked up and pulled in/out on the top of the tire, I could feel a noticable movement. Then I took off the 4x4 lock hub to have a better look. I had a buddy pull the top of the wheel in and out while I looked at the hub and spindle. I could see maybe about 1 milimeter of movement between the hub and spindle. Also, when the wheel was moved, there was some squeaking. Not sure if that was coming from the bearing or the caliper. Didn't have time to take off the caliper too.
So, does it sould like the bearings are toast? If so, I'll just pull off both hubs and take them to the local machine shop to have the bearings replaced. Humm... . would also be a nice time to do the rotors too.
Cheers,
Sean
Cheers,
Sean
