Gotta vent yall... I live in Illinois and like a good boy follow the law to a T with my 05 2500 having D plates on it and getting safety inspections every 6 months. At my last inspection (first since buying truck) the inspector passed the truck but noted that I needed to get the parking brake working before my inspection due by the end of June.
Note: my brakes worked perfectly before this all began, and had alot of wear left!
So a week ago, I pulled the rear end of the truck apart for what I had hoped was a simple adjustment of the parking brake shoes. What i found was the Previous owner had gutted the shoes and hardware completely for the parking brake, so I decided to order the parts from Rock Auto and began reassembling the rear brakes.
As I was putting the drivers side back together the friction material seperated from the backing plate.. Great, new pads. I got new pads and threw them on, as I needed to haul some hay on Sunday. Saturday evening I pull the truck out to go to my son's little league game.. Drive 3 miles to the park, drivers rear brake smoking like its on fire! Great.. Now the caliper is seized up! So yesterday I went and got a new caliper, all was going well reassembling this time. As I was setting the caliper in place I noted the banjo fitting on the brake line was alittle wet and dripped one drop of brake fluid on the rotor... I take it off, reclean the banjo fitting, reseat the copper washers, retighten, then go to clean the brake fluid off the rotor... Rotor is cracked in two spots from the hub up all the way across the area the pads ride on... Great, now new rotors.. and the banjo fitting is still leaking!
I ordered the new mopar rotors last night... waiting for them to come in...
What the hell did I do wrong? I have done brakes on hundreds of vehicles and never had this kind of issue.
What is the proper way to run the calipers back when installing new pads? I wanted to open the bleeder and push them back with a C clamp but the bleeder was froze, so I just slowly pushed them back... What is the proper way on these Dodges? Might this have caused the caliper to sieze?
How the heck do you get these banjo fittings at the caliper to seal? I don't know what else to do besides maybe get a new brake line????
