ft spring spacers
tub enclosure-want to replace bottom track
Just got B&W installed, ready to tow
Has any one here put on there truck ft end the spacers used to raise the ft end of there truck to level it out. I think it is about a two inch spacer. And if you did have you placed a camper in the back and does the ft end level out evenly with the back or is it now raised under full load. . With my truck the back is raised but when the camper goes on the weight of the camper levels out the truck. I just like the look of the truck when it is unloaded to look level.
you really don's say what spacers you're looking at however if it is the 2" hard rubber spacer that goes onto the spring it will move your front wheels back in the wheel well 1" to 2", there is an adjustment that can be made if you do the forum searches to fix that, they will make your truck level empty however, my experience running these when I hooked on a loaded trailer my nose raised and I lost level, I no longer run spacers so that I am level loaded. you could address this loaded issue with Timbrens of air bags on the rear, Hope this helps
