To try and make a long story short. My 04. 5 in my Sig has had a Silverline 4" Turbo back installed for a few years. The finish and fit is great. The system comes with a "muffler" that is about 1" larger diameter then the 4" piping. The louvers inside the muffler when installed are pointed down exhaust stream flow, so no exhaust goes into muffler packing.
I was tired of the drone when towing my 44' Pace American two car trailer loaded(24,500 cat scale). I orderd a 4" FTE Resonator and installed it under the cab. I would say under the passenger front seat on my quad cab. The drone at highway rpms, 2000-2200pm pulling grades is now gone. The resonator really does what it claims. The noise out of the tail pipe even has more a "whistle" turbo noise, which I am sure is caused by the air spiraling through the resonator.
I am happy with this mod except for one downfall. When pulling a grade loaded and getting into the throttle the truck with Smarty JR and mods listed would make 35-37psi of boost. The power from the amount of boost at highway speeds was very nice and I became use to it. With the resonator installed the turbo does NOT spoil as quick from a stop and at speed when rolling onto throttle my max boost is now 32 on the gauge.
I guess this proves you can Not have the best of both worlds. I will be heading West mid August and will see how the truck peforms on some steeper longer grades. EGT has not increased but maybe 50-100 at worse.
I would love to get the 5-6 psi of boost back but not sure if any other mod will help. Was leaning towards a Intake horn but not sure that will help since the resonator seems to be a culprit.
