Details here: TDR Privileges
any body else running a fuel cell if so what did you do with your return line ? inter from the top with a stand pipe close to the bottom only or did you add a collection tank on the inside to stop foamy thank George
the Red Rocket [Nowel's] is through the top and into the foam inner "sponge" ... seams to break down the foaming before it's to the bottom where the pick-up is
I have the 12 gallon from Summit. For the return line, I drilled and installed a breather in the top of the cell. I built a bracket and mounted the cell in my bed. I ran the braided stainless fuel lines down through the bed and along the frame rails. Works good as long as you don't need the full bed for hauling.
