Fuel conditioner Type/price/
New TST gauges
Do you want rear disc brakes?
What fuel conditioner do you use and what price is it in the quart or pint or gallon? What is the ratio of conditioner to fuel for the final cost. What does it say it does? Improve mileage, lower pour point etc. ? With the fuel costs which one will work the best and do the most for the least $$$
Sincerely, Kevin
I have been using Red Line's 85+ (a. k. a. Diesel Fuel Catalyst, same formula. . now) since 3k mi. in my '98. 5 ISB. I was instructed to use 1 (12 oz. ) bottle for an initial treatment, adding a ratio of 1. 5 oz. per 10 gal. of fuel as a maintenance dosage. 85+ lowers the pour point of the fuel, raises the cetane rating as well as increasing lubricity. I purchase the 85+ directly from Red Line, by the case (qty. 12 per case), 1 or 2 cases at a time thereby getting the fleet discount. I am very satisfied with their product.
'98. 5 2500 QC 4x4, (BLACK) SLT Sport, ISB, LWB, 3. 54 LSD, A/T, Glasstite Vision II canopy, Line-X bed liner, 285/75R16 BFG A/Ts on 16x8 M/T Challengers, Warn 4X Boards, Mopar fender flares, front and rear NW Custom stainless steel/rubber mud flaps, Mag-Hytec diff. cover and trans. pan, Edelbrock IAS shocks, Mopar tow hooks, Jordan Research Ultima 2020 trailer brake controller, VDO Vision gauges, '00 Sport headlights with PIAA Super White 9007/9004 bulbs, 4-2-7+4 Brite-Box, PIAA Dual Sport 900 auxiliary lights, BD exhaust brake and TorqLoc, Prime-Loc fuel filter relocation kit, Bosch 275 hp. injectors, VA CPC, DD Boost Module, Banks Stinger wastegate actuator, "Scotty Air System", BLACK '00 valve cover, Banks Stinger 4" dia. stainless steel exhaust system, BD LV V10/Cummins hybrid TC and valve body, BD modified transmission front pump and PressureLoc, plus many other trick modifications
I have used "power service" diesel fuel supplement since I bought the truck. 96 oz. will treat 300 gal. of fuel. Cost is $9. 97 at Wal-Mart; more at a truck stop or convenience store. It will help lube the internals of the injection system and absorb incidental amounts of water/condensation in the tank. I'm real pleased with it; don't know if it directly helps milage or performance. But by keeping things clean, both will be kept at optimal levels. The real proof was when I had to change out the faulty fuel guage sending unit in the tank. The tank bottom was perfectly clean - no crud or water or sludge whatsoever!
95 2500, clubcab, 2wd, longbed, a/t, 3. 54, 122K miles, "all the usual refinements"
Been using Cummins Premium Plus additive. About 9 oz per 30 gallons fuel. No complaints.
Jim... (KF7IS) '99 Cummins w/Dodge QC,SB, 5sp,4X4,265/75BFGs,16/8AR,VA CPC,DD Elbow,Xenon Flares,Mopar Stepbar, Rhino Guard,Amethyst Pearl,IC-735,TM-221A,25LTD-ST,
http://www.dieselram.com/images/ramjam1.jpg
[This message has been edited by buzzard (edited 05-06-2000). ]
Hi Oil Man
I have used "Stanadyne Performance Formula" for about 5 years with good results. It lowers pour point, raises cetane rating, combats rust & corrosion and provides lubrication for the injection system. The cost is $60 per case which will treat 720 gallons that figures out to a little over . 08 per gallon. I purchase it from my local Bosch authorized rebuilder. In addition they tell me they have rebuilt VE pumps with over 250,000 miles showing normal wear using this product.
Happy Trails
'93 Banks Power pack, K & N air filter BD power injectors and tweaked pump. 27lbs boost unloaded.
[This message has been edited by Bob Beauchaine (edited 05-06-2000). ]
Ditto on the Stanadyne performance formula, it also increase's the cetane level. I mail order it from DIS (disesel injection services) by the case, 6 half gallons delivered is about $93. 00 and this treats 1,440 gallons. 8oz per every 30 gallons of fuel. link to their site at: http://www.dieselpage.com/additive.htm
Terry S. '98 Quad Cab SLT, 2WD, 12V, 3. 54, AT, Trailer tow PKG, Camper PKG, OEM cab lights, 4" exhaust turndown, 5th W. Hitch, roll-top cover, tint, high performance K&N air filter, 265 Michelins and turbo silencer ring in tool box!
BOMB'n in Tacoma, WA.
Member of the NW B. O. M. B. er's
18,900 miles - 4/16/00
Buzzard,
What was the price you paid for the Cummins product?
John, What is the price you paid for the Red line product?
Thanks guys keep the good info comming.
Kevin
howdy--have used Cummins Premium (abt $11/quart) and good for 125 gal---have changed to the stuff from Lucas for abt $23/gal (8oz per 25-30gal)
Cummins stuff claims--clean injectors and increase lubricity
Lucas claim--increase lubricity----since I only get FlyingJ or 76 from Jones Feed (both stations pump huge amts of D-fuel, so the injector cleaning shouldn't be a big issue)---had no complaints about either product, but figured the stuff from Lucas more cost effective for my conditions,,Cummins may have been overkill for my purposes---neither one seems to affect mileage, and for injectors that are nice and clean already, neither one will, and neither one claims it---I, for one like a slippery pump #ad
(sorry, couldn't resist) rich
oops! I lied--- the jug of Lucas fuel treatment does claim injector cleaning, as well-- and "should pay for itself in fuel savings alone" ---isn't that what we keep telling our wives for BOMBing dollars??
I also use power servace after a friend suggested it to me. He graduated 2 years ago from Northwestern College in diesel mech, all A's except english. That is a good enough recondmation for me. I also buy it from Wal-Mart.
1996 2500 regular cab,long bed, 4x4, 5 speed, Rhino Liner
Stock plate must have slid forward when I hit the brakes
-- email address removed -- , Great Lakes TDR
PURDUE STUDENT  GO
BOILERS
Dodge Makes it
Cummins Shakes it
Another ditto on Stanadyne Performance Formula. Started using it with my GMC 6. 5TD primarily for increased lubricity (sp?).
'01 2500 QC SLT (white/mist gray), 4x2, SWB, Cummins, Auto, 3. 54 LSD, Tow Package, 4-wheel ABS, Luverne SS Side Entry Steps, Reese 18K Classic, Tekonsha Envoy. 24' SunnyBrook 5th Wheel. N0MEU
I use Morey's diesel quench. One quart treats 250 gallons. It runs about 6 or 7 bucks. Pretty much same claims as above, raises cetane level,cleans injectors, yada yada yada. The main reason I use it is for the added lubricity. The low sulfer fuel #ad
that they have now just don't cut it.
95 2500 SLT Laramie 3. 54, automatic,Herculiner bed liner, JVC cd out of factory infinity system, southwest grill gaurd (a favorite amongst the deer population), K&N, AFC adjusted, dual straight exhaust out of "gutless" cat everything else stock--don't wanna trash the transmission
Oil Man, I believe I paid $50. (ea. case) for the last two cases of Red Line 85+ I purchased (1 case = qty. 12, 12 oz. bottles).
I started using the Red Line 85+ at 3k mi. ; when my OE injectors were swapped out for the Bosch 275s at 18k mi. , the injectors looked extremely clean. We (NW BOMBers) performed several injector swaps lately with one Rammer using the Red Line 85+ albeit, only semi-recently, the other using no diesel fuel conditioner. The condition of the OE injectors was such, that you could easily tell which one had been using the Red Line product.
Red Line also states that in addition to what I listed in my last post, the 85+ also reduces smoke, prevents rust formation, removes water, conditions seals, and can reduce wear when using low sulpher fuel by 75%. I have had extremely good luck with Red Line products! Their SI-1 (gasoline) "injector" cleaner has saved me NUMEROUS times, especially at home with seasonally used epuipment. All of the Red Line products I have used have always delivered as promised.
Red Line can be reached at: www.redlineoil.com
'98. 5 2500 QC 4x4, (BLACK) SLT Sport, ISB, LWB, 3. 54 LSD, A/T, Glasstite Vision II canopy, Line-X bed liner, 285/75R16 BFG A/Ts on 16x8 M/T Challengers, Warn 4X Boards, Mopar fender flares, front and rear NW Custom stainless steel/rubber mud flaps, Mag-Hytec diff. cover and trans. pan, Edelbrock IAS shocks, Mopar tow hooks, Jordan Research Ultima 2020 trailer brake controller, VDO Vision gauges, '00 Sport grille, '00 Sport headlights with PIAA Super White 9007/9004 bulbs, 4-2-7+4 Brite-Box, PIAA Dual Sport 900 auxiliary lights, BD exhaust brake and TorqLoc, Prime-Loc fuel filter relocation kit, Bosch 275 hp. injectors, VA CPC, DD Boost Module, Banks Stinger wastegate actuator, "Scotty Air System", BLACK '00 valve cover, Banks Stinger 4" dia. stainless steel exhaust system, BD LV V10/Cummins hybrid TC and valve body, BD modified transmission front pump and PressureLoc, plus many other trick modifications
John, good link!! The Redline oil site was very detailed about the 85+, now to see if their is a dealer within a hundred miles of here. Reagards Pete
99'3500,quad cab,4X4,a/t
3:54,all the right packages!PROPER VALVEMENT
You need to go to the TDR links on the opening page of this web sight and then to the section on how to build a high performance cummins and read what this guy has to say about Lucas oil,he recommends it highly.
Thanks for the info guys. I will try and find out which ones give the most benefits with the least amount of $. I have a lot of info off the web sights also and will post the info when I've got it all together.
Sincerely, Kevin
Pete, you can order Red Line products directly from Red Line. I had to start doing this when the local sport car shop (that stocked almost the entire Red Line, product line) went out of business.
Oilman, all- I overheard a conversation between a group of vetran truckers, and they ALL were comparing notes on the low-sulphur fuels they were having to run. Without exception, they all agreed that one-half quart/50 gals of fuel of el cheapo auto-transmission fluid was the answer, at least for lubricity. (red color was not a problem). Anyone have any comments? Thanks-Ron
2001 QC Dually SLT+ 354 LSD AUTO 4WD Driftwood SS Railcaps Stainless Werks step-rail nerfs Rhino spray-in liner Aux B/U lites Diamond Plate Alum Highways tow box SS Fender lips Jardine 4" Mag-Hytec diff & transmission Alcoa classics Reese 20K hitch 28ft Holiday Rambler 5er w/slide 84 Scrambler 4" lift 33/12. 50's 4. 56 gears soft locker/trac-lok Built 258 w/Mopar fuel injection conversion BUILDING 66-442 Olds, ground up--OH BABY! NRA 25 YEAR MEMBER
Frijole,
Auto trans fluid has a high detergent additive that you would think should clean injectors and lube the pump etc. But the other additives in the ATF are harmfull and will leave other harder to clean up carbon and deposits in the combustion area and rings. I would have to advise against this.
Sincerely, Kevin
oilman--I guess I should have mentioned this in my post--THE ONE THING that also was stated by above mentioned group, was that when they did a tear down, there was absolutely no carbon anywhere. Even more astonishing, was there was no need to use a ridge reamer to remove the pistons. The combustion chamber was clean as a whistle. These guys are talking 150 to 200K miles on these rigs without any adverse effects from using transmission fluid as a fuel additive. These old f%#$ must have enough road miles to know what works and what doesn't. Me?, I don't know squat about fuel conditioners, but I was VERY curious about their statements. Kick this around with other "old" truckers and see what kind of response you (all) get. Ron
