Well I have read a fair amount on the forum re: occasional stalling and sputtering…. symptoms I am having on my 94 with 225k. Two things I noticed that I did not see mentioned.
1. When changing the fuel filter I poured out the contents and noticed some small black flaky material, not a lot. I also noticed the same material in the heater screen. Cleaned and replaced both and she ran OK for a couple of weeks.
2. Today when symptoms reappeared I decided to drain a little fuel from the filter (Fleet Guard) and noticed that it came out VERY slowly. . dripping as opposed to a “normal” flow. I also saw one of the black flakes. They disintegrate rapidly upon touch.
The engine sputtered and would stall if I backed off the throttle, but it cleared up in about 3 miles. I heard a ticking sound when it was at its worst, something like the hydraulic tappets did on my ’56 Olds back in the dark ages.
I am leaning toward contamination and guess that the “ticking” was a clogged injector, though of course that could be completely off.
I will cut the filter tomorrow and check for contamination.
The return fuel line was replaced about 50k ago with steel braided racing line.
Any suggestions would be appreciated.
