Fuel Cooler on Return Line ??
Delayed Shift - Cycle Fuel Pedal Solves Problem
Huge Boost Leak Found, How to Fix?
I realize that our trucks have a large volume diesel tank that perhaps might mitigate the need for a diesel return line cooler, but I am wondering what you guys think about this SAE published article concerning diesel return line collars on HPCR engines in order to keep diesel temps from climbing.
Here is the original technical reference, but skip below it and you can read the entire text without paying for download
https://www.sae.org/publications/technical-papers/content/971807/
Here is the text of the article above from a post on VW Tdi forum.
Fuel Cooling Needs for Advanced Diesel Engines
Michael Davies, John Burgers, and Nick Kaiman
Echlin Corporation
Design changes in high pressure diesel injection pumps have increased the heat input to the fuel beyond acceptable levels. This paper describes the source of the extra heat, its effects, and various ways of dissipating it.
INTRODUCTION
With the progression of legislation (CARB, EPA, EC, etc.) to lower vehicle emissions, there is a need to further reduce tailpipe emissions from diesel powered vehicles. Diesel engines offer an advantage over their gasoline powered counterparts because of their durability, lower fuel consumption, safer less volatile fuel, and low Hydrocarbon (HC), Carbon Monoxide (CO), & Carbon Dioxide (CO2) emissions. The challenge facing the diesel industry is to lower Oxides of Nitrogen (NOx) and Particulate Matter (PM) emissions without hindering vehicle performance or efficiency.
This tightening up of allowable NOx & PM emissions is pushing conventional emissions control strategies beyond current capabilities. Development in current technology includes both in-cylinder and after treatment emissions control strategies. After treatment strategies include after burners, particulate traps and filters, close coupled catalysts, and lean NOx catalysts. Fuel additives and fuel refining chemistry changes are also beneficial in reducing emissions. In cylinder control of emissions involves controlling the location, duration, timing, and time-volume history of combustion. Physically, this translates into keeping the flame away from the quenching effect of the walls, controlling the amount of lubricating oil entering the cylinder, the placement and direction of the fuel spray and the combustion bowl geometry. Recirculating combustion gases back into the cylinder intake (Exhaust gas recirculation) also reduces emissions. This effect is enhanced by cooling the returned gases as more mass can be returned. Normally, though, EGR can only be done at part load. Electronic control of the fuel injection has greatly reduced emissions by taking advantage of variable timing, controlling the time-volume history, and utilizing the ability to map the limits of fuel injection to prevent excessive smoke generation. Breaking the injection into multiple events is also beneficial. Mostly, however, there has been a change towards direct fuel (DI) injection rather than indirect (IDI), and a trend towards higher injection pressures for better control of the spray and its duration. The high pressure fuel injection strategy greatly increases the work input into the fuel and substantially raises the fuel temperature. There are, however, various strategies for cooling the fuel to manageable temperatures, the drive cycle impact on fuel cooling needs and the causes and effects of high fuel temperature.
MOTIVATION FOR FUEL COOLING
Why Is There More Heat?
One solution to increase performance, increase mileage and reduce emissions that is showing promise is to raise the injection pressure of the fuel, in some cases to 1600 bar (23520 psi) with rotary injection or common rail pumps, and even higher to 2,000 bar (30,000) with unit injectors. This will lead to finer fuel atomization and better rate shaping. The higher pressures allow for the fuel to be injected in a more tightly controlled window of the crank angle, which optimizes the combustion event. To reach the full benefit of electronic control of fuel injection, designers of injection systems are also employing high speed solenoid valves to end the injection event. Such quick injection ending reduces unburned HC and PM formation. However, this new strategy increases the work in the spilled fuel in comparison to older technology injection pumps which incorporate an 'over the cam' approach to control the injection event. Newer electronically controlled high pressure injection systems can produce 0.15 to 3.OkW of waste energy to the recirculated fuel, versus older systems which create 0.15 to 1.8kW. This increased waste energy elevates the fuel temperature above that tolerable at the injection pump inlet.
Why is There a Temperature Limit?
There are many reasons why the fuel temperature needs to be limited:
1. Modern HSDI engines for passenger cars are designed for operation at an optimum fuel temperature of 45 oC.
2. Increased temperature reduces the density of the diesel fuel. Since a constant volume of fuel is injected on each stroke, the reduced density means that a smaller mass of fuel is available to be burned, affecting the stoichiometry of combustion and also reducing engine power.
3. Increased temperature reduces the viscosity of the diesel fuel. The reduced viscosity increases the leakage flow past the pistons of the injection pump, which increases the drive power and pumped volume of the injection pump.
4. Increased temperature increases the bulk compressibility of the fuel. The pump must therefore do more work to pressurize the fuel at a higher temperature. It also affects the pressure wave dynamics.
5. A limit exists on the fuel tank temperature due to the use of plastics. As well, other material compatibility conflicts arise with the use of elastomers.
6. Fuel lubricity is reduced at elevated temperatures. This is very harmful as the fuel itself is used to lubricate the injection pump.
7. There is also incorporated integrated electronic circuit chips onto injection pumps, which must be cooled below their 120 °C limit.
8. Due to the extremely precise and small volume of fuel per injection event, each injector must supply the same volume of fuel at the same temperature.
Which Vehicles Need Additional Cooling?
Which vehicles need fuel cooling and which do not is largely dependent on the expected drive cycle. The fuel temperature rise is strongly dependent on engine speed and only slightly dependent on torque. Higher speed engines have a greater need for fuel cooling as the fueling parameters must be controlled in a tighter time span and crank angle. The same quantity of fuel must be injected in a much smaller time increasing the work input to the fuel.
It is important to consider the drive cycle impact on the need for fuel cooling. If the intended drive cycle only requires cooling for transient applications, then there is the potential for the thermal capacitance of the system to partially cool the fuel. This is especially true as the transient temperature limit at the injection pump is often somewhat higher than the steady state value. Of course, the steady state problem cannot rely on any thermal capacitance to reduce the fuel cooling need. Those engines that spend much of their time operating in low gear, high RPM often have a need for steady state fuel cooling. This include combines and delivery trucks. Passenger cars do well have such a need, especially when they are used for freeway driving conditions.
In sizing the fuel cooling system, it is important to take into account the thermal resistance of the rest of the fuel system. This includes the lines and especially the tank. Depending on local ambient conditions, these components can act as fuel coolers or heaters, and this must be quantified. Decisions can be made that will increase the cooling benefit from these components. For example, if the tank is acting as a fuel cooler, then it is beneficial to design the in-tank canister to mix the return fuel with the bulk fuel as much as possible. On the other hand, if the tank is acting as a heater (air temperature near tank is hotter than bulk fuel), then a non-mixing canister is desired.
STRATEGIES FOR FUEL COOLING
There are several strategies for fuel cooling that can be pursued for automotive applications. Each has their own advantages and disadvantages as outlined below. If the need for fuel cooling is identified early in the design of the engine, then it is possible to engineer solutions that deliver many benefits that otherwise be available. For example, if a fuel recirculation loop is employed to the clean side of the filter, the fuel filter can be made much smaller due to the reduced flow. This also will greatly minimize the temperature rise in the tank.
Air Cooled Fuel Coolers
Cooling diesel fuel with air often has the appeal of being considered the lowest cost, least impact solution. The limiting fuel temperature is that of the ambient air, which is often the lowest temperature heat sink on the vehicle that is easily available.
The primary disadvantage is that the cooler must be mounted in a 'crash safe zone,' precluding installation in the radiator package. This limits the permissible packaging space to behind the front face of the engine or under the body of the vehicle. In both of these areas, there are generally high ambient temperatures and low air velocities. These factors cause the heat exchanger to be large relative to the space available. If the fuel cooler is to be mounted in the engine compartment, an electric fan or air ducting to the front of the engine or both may be required, adding greatly to the system cost and packaging space. These additional components supply the air at an appropriate velocity and temperature.
Similar problems occur for fuel coolers mounted underbody. Air flow here is strongly dependent on many factors, including body shape and design, wind direction, and vehicle speed. It is possible, however, to control the air flow to the cooler through suitable ducting of the ambient air. This should be done in such a manner that prevents it from mixing with the radiator outlet air stream. Ideally, the cooler should stay forward and low on the vehicle underbody.
The primary disadvantage of attempting to use engine coolant as the heat sink is that the fuel cannot be cooled below the outlet radiator temperature, which is around 100 °C. This is higher than the optimum 45 oC.fuel inlet specification on current rotary distributor and common-rail fuel injection pumps.
CONCLUSION
Fuel cooling is a definite need for advanced diesel engines based on fuel pump design and anticipated drive cycle. Several paths are available to the engineer in choosing an appropriate strategy to cool the fuel.
SO I have room on the DS frame rail, in between the tank and the Mopar SDFK that I have installed on my truck, for one of these heat sink/chamber coolers. This one is a dual pass int hat the chamber has a divider in it, allowing the diesel to remain in the contact with the fins for longer.
https://www.jegs.com/i/Derale/259/13264/10002/-1
It would be extremely easy to cut into the fuel return line at that point and re plumb it through the cooler just before the line goes back in to the tank...Certainly can't hurt, right??
Cooling it on the return circuit would be the place to do it along with keeping the tank as full as possible. Not sure it is needed though, no hard information on what fuel temps actually are in the tank
Too true about the lack of temp info, but for less then $100 I think I'll try this as my next mod.
The return line is the smaller of the two steel fuel lines running along the frame, right??
I myself would not install a fuel cooler on my truck, as this paper was written for the higher RPM engines such as the Ford Powerstroke or the D-max engines and the smaller diesel engines in foreign cars. If you notice in the white paper the authors refers to High RPM engine operation. And I quote " Which Vehicles Need Additional Cooling?
Which vehicles need fuel cooling and which do not is largely dependent on the expected drive cycle. The fuel temperature rise is strongly dependent on engine speed and only slightly dependent on torque. Higher speed engines have a greater need for fuel cooling as the fueling parameters must be controlled in a tighter time span and crank angle. The same quantity of fuel must be injected in a much smaller time increasing the work input to the fuel."
The Cummins engines in our vehicles seems to operate at the optimum operating range between 1500 and 2000 RPM's. Most modern diesel such as my wife's VW TDI seems to operate above the 2000 RPM range which to me seems high for a diesel engine.
I have always instructed my wife and I practice this regularly to keep the diesel fuel tank at least 1/4 full and never go below that level. I have told her that the fuel in the tank is providing cooling for the returned fuel.
My opinion.
JimW, you are likely correct about the need for installing a fuel cooler on lower RPM engine like the ISB, particularly when it has a larger volume fuel tank. That being said, with the type of cooler I will use and protected frame mounting location that I am thinking of, I see zero downside to it.
The rule I see on big trucks as far as a fuel cooler being STANDARD equipment is if the fuel capacity is 50 gallons or less with 12L or larger engines. If they carry more fuel than that the cooler becomes an option (That you don't see very often).
A fuel HEATER of some type is a far more common option.....
Its this simple, Keep your tank full when convenient, HWY Driving/speeds in hot summer months for long periods of Time don't drop below 1/4 tank.
Scale at 15,000 PSI the lift fuel temp 40-50F 20,000 PSI 50-60F its about 10F for every 5,000 PSI after 15,000 PSI.
Cold fuel makes More HP this was tested, The Engine we use 1800HP the fuel was routed VIA ICE Box coil style cooler submerged in Mixed ice water temp 26F it made 32 more HP.
I have the most advance filtration/lift system on all My Diesel trucks (House built) do I have coolers NO, I just keep My tank(s) full when convenient.
Now if you add any type of return fuel cooler is just to risky. if pressure builds (above3-5PSI) in the return system the injector(s) may pop the solenoid O-ring(s) you will be mixing oil/Fuel form 1ML to 100s ML per minute .
if you want to cool your fuel Add auxiliary cooling Plat-fin design, the Duramax had this cooler for years mounted just in front of the Fuel Tank.
Seems to me the risk exists with or without a cooler....if excessive pressure pops an oinejector solenoid o-ring, then oil is going to be mixing with fuel whether or not a cooler is present right before the return line re-enters the fuel tank.
This is a pic of the cooler I plan to connect to the return line and mount just in front of the tank.
While it is NOT as effective as a tube and fin or stacked plate cooler, I do believe that it will help keep the return diesel cooler before it dumps back into the tank.
Seafish, I don't think the surface area is enough to make the difference worth the effort, I see NO alternative other than Plate/Fin.
Todd FYI--
that cooler is a double pass chamber that holds just over a pint of liquid, or 500 ml, and the fins extend INTO the chamber.
If normal ISB injector return rates are 180 ml/minute, that means the fuel would be inside the heatsink chamber for about 3 minutes...MAYBE enough to make a difference.
If I had the time and energy, I owed add some thermocouples to get some pre and post cooler readings. In a pinch, I will use an IR thermometer to check pre and post cooler fuel line temps.
That being said, the Duramax cooler is available for $140 shipped and could easily mount in front of my diesel tank much like it does on the Duramax. It is interesting to note that the way it mounts on the Duramax, directly on the front end of the tank, seems that it would NOT allow a lot of airflow through the fins to cool the fuel, unless their is a fan on the back that I can't see.
REALLY don't want to add a fan just for fuel return cooling, though MIGHT if I was to double stack coolers on a system for fuel return AND G56 transmission fluid cooling. NOW THERES AN IDEA!!! LOL!!!
Just thinking out loud here...MUCH appreciate any and all feedback!!!
For thoe who want to see, here is a video of the oem fuel cooler on a Duramax--
New OEM HPCR 5.9 injectors return 8-10ml P/M at Idle, the CP3 Returns 150ML P/M at idle So your looking at 210MLP/M at Idle.
The 5.9 / 6.7 CP3 R/T 400-500ML PM at 1700 RPMs. there's 100ML difference on the COVs installed on the Pump. A modded GP can pump 120-180 GPH. at 3200 RPMs OEMs about 60-100 GPH Vs Combustion use.
I ask this same question a few years ago about cooling the return fuel and was told it would not make any difference in performance. But as you know your truck runs better with cool fuel than when its been run on a hot day and the full is a lot warmer. This is a good concept and would like to see some positive results.
