Fuel delevery problem
Speedometer AND odometer do not work - help
Truck quit
Hi guys, I'm having A fuel problem on a 1992 W350 Dually with 150,000 on it. It seems that the fuel runs back to tank when setting over night, I'm having to crank way to long to start, It will finally start and then run out again, After the second time starting it is fine till the next day Thanks jack
sounds like you have a leak in the fuel line some where and is letting the fuel drain back, so just start checking lines.
