Fuel Delivery Gauge For Idiots
Stealth Sub Enclosures
No Offense!
Right now I can produce a brief burst of black smoke from the tailpipe when I rapidly depress the gas-pedal—yes, I know, but I’ve called it that for 30 years—when the engine is running at low RPM. This seems like an indication that the fuel delivery system is working well. Is this a way to assess the functionality of the injection and/or lift pump?
If at some point I notice that I don’t get as much smoke--or none at all--in this situation, can I use this simple method to diagnose a problem? I know I won’t be able to pinpoint the problem, but this seems like a way to keep an eye on the fuel delivery system without fuel pressure gauges?
What do you think?
2001. 5 3500 QC 4X4 6-speed HO 3. 55 black
1998 Jeep TJ black http://www.nm4w.org/members/puffer.htm
PUFF, if your dead set against or don't wish to spend the $$$ on a FP gauge, I think a better indication will be a stumble. I had one with my truck pre-Mallory, scared the heck out of me.
That being said, I had and did alot of mods. to my truck when my 4" exhaust (BD) went on. I thought I was fairly smoke free, unless under hard acceleration with low boost. The BD came with a turn down tip. I just put a 5" straight tip on and now that it's pointing straight out, rather than down, smoke is a non-issue, that is, I have plenty for everyone. The point is that the smoke was always there, just couldn't see it in the RV mirror with the turn down tip. If you do nothing else, pick up a temporary gauge and check your pre-filter psi's at idle, if you have a concern. Just my $. 002.
Scott W.
White 2001. 5 3500 ETH/DEE 4X4 Quad cab SLT,tow package and camper prep,Husky liners front and rear,DiPricol pyro,boost and oil temp gauges,SPA fuel pressure and temp. gauge,Edge EZ,Psychotty air,Bully Dog stage III injectors,ATS 3 piece manifold,HX40 turbo,4" BD exhaust,4" BD E-brake,McLeod clutch,Mallory 4150 lift pump,Mag-Hytec rear,Go-Rhino grill guard,Lund bug shield,PM tractor utility back up lights,Penda bed mat,365. 8 HP on the dyno and blow by bottle is bye bye !!! I love the smell of diesel in the morning, it reminds me of... . VICTORY !!!
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089608" TARGET=_blank><font color=red>My Truck</font></A>
<A HREF="http://albums.photopoint.com/j/AlbumIndex?u=1231655&a=9089604" TARGET=_blank><font color=red>THE SAINTS</font></A>
[This message has been edited by Bigsaint (edited 05-18-2001). ]
Thanks Scott.
I'm in the process of ordering gauges, and I know I should get a fuel gauge, but the fuel guage is just as expensive as the pyro and boost gauge combined.
Just being cheap I guess. If I do put one in, where is the best place to connect it?
unless it just has to match an oil pressure gauge works great and they are way cheaper.
97 SLT Laramie CC 5spd, 3. 54, Ranch Hand front and rear. Lotsa goodies coming soon. Oh oh dang cat fell off. Member NRA/USPSA
BigSaint,
I ordered the Westech fuel pressure gauge from Geno's, but don't have a clue how I'm going to install it on my 2000. I don't want to connect the 6 oz sending unit on the schrader valve since I'm worried it will break. Has anyone fabricated a hose to remotely mount the fuel pressure sending unit? Anyone know where I can get a 4AN to 1/8 NPT fitting. Part number???
Thanks in advance,
Charles
2000 QC 2500 4x4 LWB ETC/DEE, Anti-Spin, 3. 54, Trailer Tow, Camper Special, DD1's, PS boost module, PS high idle kit, PS steel idler pulley, Autometer boost and EGT gauges, Westin nerf bars, Rhino Liner
My Toy
1969 Toyota Land Cruiser FJ40
350 TBI, Turbo 400, ARB lockers front/rear, 4 wheel power disk brakes, 4. 88 ring/pinion, 3 speed transfer case, full roll cage, Warn 8274, MRT 36 bolt beadlocks with Super Swamper Boggers (16x35x15), Saginaw Power steering, custom bumpers/fenders/nerf bars/skid plate, GM tilt steering column, 6 point roll cage, RCI racing seats with 5 point harness. Loves to be pulled behind the Dodge and pass the powerjokes going up hills.
Puff, check out http://www.xks.com It's a Jaguar place. You should be able to get the whole setup for about a hundred bucks, which includes the gauge and two senders. If you only want one sender, the price will be lower. The part numbers you want are as follows:
Senders SW-82504-F 0-16 psi $27. 62 per
Gauge SW-82868-P (Black) $31. 45 or SW-82888-P (Stainless) $32. 26
Hope this helps
1999 Dodge Ram 3500 Quad Cab 2wd; 5 spd; 4:10 LSD rear; Mag-Hytec differential cover; US Gear EGT and Boost gauges. Stewart Warner Fuel Pressure Gauge with dual senders, Westach Oil Temp Gauge for differential. Rancho 9000 shocks, PowerEdge EZ Box, Amsoil foam air filter and synthetics in the motor and differential. Cummins Power, don't leave home without it
[This message has been edited by John Berger (edited 05-18-2001). ]
