rbattelle
Since I bought this truck I have been very concerned with longevity issues with regard to the CP-3 and injectors. Common rail injectors are significantly more prone to wear at the needle and seat than traditional jerk-pump type injectors. Add in the incredibly close tolerances required to generate 1600 bar in the CP-3, and you’ve got one very sensitive fuel system. I’ve heard (rumor) that Caterpillar is now running 2-micron filters as standard equipment as a result of their own research on the effects of particles <5 micron in US diesel fuel. We’ve seen the terrible experience some Duramax owners have had with their Bosch common rail systems. Until recently, I was too concerned with retaining my stock fuel system for warranty purposes to actually do anything about it. Well, events at my servicing dealer have revealed to me that I can no longer fully trust them to handle my truck, and I must take things into my own hands. In other words, I’m no longer concerned with my warranty. I have begun what I am calling “Project Number Two” (which is either a clever reference to #2 diesel fuel or a crude reference to a bodily function, depending on what you think of me and my idea!).
Project Number Two is a re-design of the stock fuel delivery system. I set forth the following goals in prioritized order:
1. Improve fuel filtration 5 times over stock (to 2 microns absolute)
2. Improve fuel delivery reliability and consistency (flow and pressure)
3. Improve serviceability
Along with these goals, I have defined the following objectives (in no particular order):
-Use industry standard components wherever possible
-Some consideration to affordability
-Minimize fears of fuel gelling/filter freezing problems in cold weather
-Modular construction
-Provisions for easy fuel transfers and testing
-Features for easy emergency service
Since my number 1 goal is to improve filtration I spent the most time researching filters and filter assemblies. Some of the filters I looked at were:
-FASS
-Fuel Preparator
-Nicktane (a 2-micron Caterpillar filter adaptor)
-Racor
-Dahl (as sold by Amsoil)
-Various options from Fleetguard
-TP systems (Motor Guard and Frantz)
Each of these have their pros and cons, and they're all outstanding systems. None of them offer me what I want in a complete package. The package I want is:
-2-micron absolute filtration (or better)
-Option for a 12v fuel heater
-Integral fuel booster pump
-Standardized connections
-Retention of the stock fuel filter
-Compatibility with 100% biodiesel
-Provision for a fuel pressure gauge
-Ability for future expansion (such as an Espar coolant heater)
-“Quick” component changes in emergency situations
I spent a lot of time trying to decide where the new filter should be positioned, and (to make a very long story shorter), I have decided that the best way is to mount my supplemental filter between the stock filter and the CP-3. As far as I’ve read, the industry standard in multiple filtration systems is to run them in series gradually stepping down in micron rating. Since the stock fuel filter is 10 micron absolute, then a 2-micron filter should be downstream of it to comply with the standard. In addition, mounting it after the stock fuel heater (a 300W unit) might allow me to forgo a second fuel heater for the supplemental filter.
Eventually, I came across the filter assemblies made by a company called Davco (www.davcotec.com). These guys make BIG filters primarily for the heavy truck industry. Their filters are purchased and re-branded by: Detroit Diesel, Mack, and Fleetguard. In particular, I’m referring to the Davco model 382 “Fuel PROcessor”. This filter is standard equipment on the following engines:
Cummins: ISX, ISM, M11, N14
Detroit Diesel: series 50 and 60
International: DT444, DT466, DT365
Mack: ASET Series and E7
Mercedes: MBE900, MBE4000
Volvo: all engines
It offers 3 fuel heater options: 12v, 24v, 120v. A 2-micron absolute filter is available from Fleetguard (P/N FS19761). It uses ½ NPT ports and has a 150 GPH capacity. Conveniently, it uses a “seeing is believing” fuel canister that is clear so it’s easy to see when it’s time to change the filter. Heated models have an integral coolant-fuel heat exchanger in addition to ports for an electric heater and thermostat. One problem: it retails for over $600. To get around that, I bought one from a gentleman on Ebay for $200 (unused but in need of a cleaning and a bit scratched up). Here’s a photo of the unit. It happened to come with a 120v heater. I have disassembled it for cleaning (and because I don’t like the thread sealant Davco used).
Here’s a key to what you’re seeing:
1 - base
2 - drain valve
3 - base attachment screws
4 - 120v heater
5 - canister base collar
6 - canister top collar
7 - filter (it came with a Mack 7 micron filter installed)
8 - fuel bowl
9 - filter spring
10 - filter canister
There are 3 o-rings that I forgot to label.
This thing is BIG. Fully assembled it stands just over 16 inches tall and is almost 6 inches at the largest diameter. It uses only NPT ports of size 3/8 or ½. I have not decided on where to mount it, but am considering making a bracket to put it on the engine just above the CP-3 where the TPS is on early-build 2003 trucks. Not sure if engine vibration is something I should avoid, however.
In order to plan everything out, I came up with a schematic, shown here:
Black items are components
Red items are connections
Blue lines are fuel lines
Letters label the fuel lines
Numbers label the connections
Fuel lines:
A - SS braided -6AN
B - SS braided -6AN
C - Factory rubber hose (3/8 ID)
D - SS braided -6AN
E - SS braided -6AN
F - Factory stainless 3/8 OD line
Connections:
1 - “Weber” fitting (M12x1. 5 to -6AN)
2 - -6AN to ½ NPT fitting (Summit Racing)
3 - -6AN to ½ NPT fitting (Summit)
4 - “Weber” fitting (M12x1. 5 to -6AN)
5 - Stainless steel disconnect (Swagelok)
6 - -6AN to 3/8 NPT (Summit)
7 - -6AN to 3/8 NPT (Summit)
8 - ½ NPT to 3/8 OD tube (Swagelok)
That list of connections is very generic: there are actually a total of 15 individual fittings that must be purchased in order to do this. I can certainly provide more detail and all relevant part numbers if there’s a desire for that here. Also, not shown here is a ½ NPT street tee that I’m installing at connection number 2 in order to facilitate a fuel pressure gauge (as an aside, that port could also be branched to provide fuel to an Espar unit).
So far I have my Davco filter and I have my Swagelok fittings on order ($161 worth of fittings). I went with all stainless steel because brass, although cheaper, oxidizes in diesel fuel. Stainless ensures maximum compatibility with all types of fuel. I know what fittings I need from Summit, but haven’t ordered them yet. I think I’m going to use the Aeromotive pump like lmills has for my booster pump, but haven’t ordered that yet either. I intend to wire this system to switches in the cab that will allow me to pump fuel manually with the truck off using either the stock lift pump or the booster pump or both.
Total cost for this system should run around $700 assuming a $200 bargain for the Davco unit. Buying it new would have made it unaffordable for me.
This is my main winter project this year. I will be assembling the components and testing everything over the course of the next several months, then installing it in the spring when the weather gets warm again. Rather than post the entire thing all at once, I decided to start this thread now and add to it as I go along. I have pretty thick skin (I think), so I’m open to criticism and debate about what I’m doing here. Please understand - I am in no way affiliated with any of the companies I discuss here, I just happen to have favorable opinions of them and their products. Also, I am not in any way saying that what I'm building is any better than systems like FASS, Preparator, or Frantz... this system is just what *I've* decided would be best for *my* application. Bottom line: I'm not "putting down" anyone else's fuel delivery system. I've done the research, and this is what I've decided is the best for me. You may decide otherwise.
-Ryan
-FASS
-Fuel Preparator
-Racor
Volvo: all engines
1 - base
2 - drain valve
4 - 120v heater
8 - fuel bowl
9 - filter spring
Fuel lines:
A - SS braided -6AN
B - SS braided -6AN
D - SS braided -6AN
E - SS braided -6AN
Connections:
-Ryan
