This is perplexing. I've installed another new lift pump. I'm reading 8 psi at cruising speed inlet, 12 psi outlet. This was the same thing I was seeing with the old lift pump, but lower pressure readings: 6-7 inlet, 10-11 outlet side. This is the second new pump that did this, so my thinking is that I've got a restriction somewhere before the lift pump. I swapped the senders around to make sure that wasn't the problem. Same thing. Lower readings in than out. I'm measuring readings at the inlet test port on the canister housing and at the outlet banjo fitting on the canister housing. When I installed my second lift pump two years ago, pressure readings always read the same on both sides, with hardly any fluctuations between the two. My fuel gauge has been very unreliable for quite some time now and makes me believe I've got a problem at the tank. What might I want to look for to solve this problem? I've got a bad feeling I'm going to have to drop my tank. Is there anything after the fuel filter housing that could cause such a difference with the pressure numbers?
