Upon replacing injectors, I stripped a few banjo bolt threads. That was too easy!! Actually, its more likely that the female threads in the injectors are stripped too, (I tried different banjo bolts on the same problem injectors, and to no avail they get stripped also. )
This is actually the second time I've done the injectors-- the first time I suspected a leak from the copper sealing washer at the injector tips-- fuel seemed to be flowing up through the hold-down nut dust boot seals. Now I've learned that the leak in the first place might have been due to overtorqueing the fuel drain manifold banjo bolts. (What is the correct torque for those?)
Does anybody know some part numbers for
1. Fuel drain manifold banjo bolts?
2. Copper "U" washers for banjo bolts?
3. . 5 mm copper washers for injector tips?
4. Injector hold-down nut dust seals?
5. Injectors?
On my third try, I don't want to mess around with old parts!! What is the fastest way to order parts online?
I hope #5 is not necessary, but with stripped threads inside the injectors, do I have a choice? I'm no machinist, but is it possible to use a hardware store tap and die set to fix the banjo bolt and injector threads?
I'm definitely a newbie here-- any help would be greatly appreciated. My truck's a work truck, so I don't know what I'm gonna do come tuesday. Thanks again.
5. Injectors?
